Scarab 2 step hull with 500EFI's or 525SC's >
Old 12-06-2009 | 10:55 PM
On Time's Avatar
Default Scarab 2 step hull with 500EFI's or 525SC's
Alright, I nixed the idea of a 38 w/ 502's - too slow. So I'll be spending a little more but I m looking at clean models w/ these engines. Any comments? Speed ? Handling? Reliability?What difference do extension boxes make if any? Thanks for all the comments for my last question.
On Time is offline
Old 12-07-2009 | 01:55 AM
Keep in mind that 525SC's will need 92 octane fuel. They are great engines, but will be thirstier and are a little cold blooded compared to 500EFI's.
Just curious, why are you looking at 38 AVS's if you have a 2005 42 Fountain???
Griff is offline
Old 12-07-2009 | 10:15 AM
On Time's Avatar
We live in Houston and go on both inland freshwater lakes as well as offshore. I dislike trailering and would just prefer to keep two boats in the two separate areas, which are about 100 miles apart.
On Time is offline
Old 12-07-2009 | 11:56 AM
525SC intake manifolds do no like salt water and they are near impossible to find used.
Griff is offline
Old 12-07-2009 | 04:05 PM
On Time's Avatar
It seems everyone favors the 500EFI. But some had valve issues, right?
On Time is offline
Old 12-07-2009 | 07:05 PM
Just to clarify, valve spring issues. Carb'd 500's had more problems than the EFI's from what I've heard. There is a TON of information on here regarding this if you perform a search. I think it was just a bad batch of springs from China that was the culprit. Swap them out at 250 hours and you should be fine. Shogrens used to have a clean 38 Scarab AVS with 500's that would be on my short list if I hadn't just bought one! I don't see it on their site now, maybe it sold?
Shallow Minded is offline
Old 12-07-2009 | 09:34 PM
Like SM said, the carbed 500HP's had the major issues with valve springs. Lots of them broke and caused major problems. Pretty much any engine with a .600 lift+ cam, like the 500EFI has, should have the springs replaced in the 250 hr range.
Griff is offline
Old 12-08-2009 | 12:25 AM
thisistank's Avatar
I think a 38 TG with 525SC's and 3A's is just what you're looking for!!
thisistank is offline
Old 12-08-2009 | 07:29 AM
On Time's Avatar
Thanks Tank nice boat I read all the articles but I don't think you can beat a used Scarab AVS at today's prices, just have to find the right one!!
On Time is offline
Old 12-08-2009 | 07:30 AM
On Time's Avatar
Is that your "sold" yellow/purple with scoops? Were the engines in your boat already serviced? Who did it? How many hours since and any further issues?? Thanks
On Time is offline
