Advice on switching from roller to bunk trailer? >
Old 12-22-2009 | 12:10 AM
Default Advice on switching from roller to bunk trailer?
I have a 23.5 foot boat my trailer now is a roller but I am going to switch it to a bunk trailer. How many bunks should I have? Should they be made adjustable? Any other input would be great
twistedvelocity is offline
Old 12-23-2009 | 10:04 AM
Any advice where they should be located exactly
Old 12-23-2009 | 12:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Depends on the trailer. Look through the classfied ads to see examples.
Most of the bolt together trailers have two large bunks standing up on end that go under your main chines.
I suggest a pair of flat 2x6s that rest around the keel inbetween the big bunks, and another pair of flat 2x6s at the front of the trailer which rest around the forward portion of the keel and guide you straight on the trailer.
http://www.mcclaintrailers.com/
http://www.mcclaintrailers.com/parts...ailer_back.gif
Sydwayz is offline
Old 12-27-2009 | 07:11 PM
Anyone else have any opinions on the bunks how many there should be and what type? Remember it is only a 23.5 footer
Old 12-28-2009 | 09:16 PM
I just replace my bunks last spring and they were 2X6`s. My boat has a stepped hull. So it had 8 risers.
My old boat was a 21'. That trailer had 2X6`s also and set up just like Sydwayz said.
capt2130 is offline
Old 12-31-2009 | 07:33 PM
got any pics of the trailer wo the boat on it? depending on the cross tubes you can use the ubolt stye posts to attach the bunks to the frame.
gofastkyle is offline
Old 12-31-2009 | 07:53 PM
not 100% sure how to post a pic lol
Old 01-03-2010 | 06:56 PM
scroll down to MANAGE ATTACHMENTS and then enter it from your computer. It'll show it's attached then you can hit SUBMIT POST
Irishtornado is offline
Old 01-03-2010 | 08:48 PM
Hope this helps its the only ones I have right now.
Attached Thumbnails Advice on switching from roller to bunk trailer?-img_0056.jpg   Advice on switching from roller to bunk trailer?-img_0055.jpg
