Go Back  Offshoreonly.com > Owners Forum > Donzi
Donzi 38 zr w/ ITS >
Donzi 38 zr w/ ITS
Donzi 38 zr w/ ITS
Old 12-31-2009 | 07:58 AM
Dean Ferry's Avatar
Veteran: Air Force
Default Donzi 38 zr w/ ITS
Can anyone speak about the +/- of having the ITS on a 38 ZR w/ 525's? VS. same boat w/o the ITS system, just regular XR's?
thanks,
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 12-31-2009 | 10:12 AM
Cash Bar's Avatar
Mod Squad Enforcer
You might need to clarify year and hull to get a true response.
ZRC,ZR, etc..
www.gregsellswaterfront.com
Cash Bar is offline
Old 12-31-2009 | 12:31 PM
Dean Ferry's Avatar
Veteran: Air Force
ZRC,ZR, etc..
Cash,
I did mention ZR model, and year wise 2007-2008.
I read that Donzi changed the ZR Comp hull bottom to a 4 step configuration in 2009.
As far as I know, Donzi didn't change the ZR bottom, is that true, anyone?
Still looking for the ITS data?
Hopefully Craig Barrie will chime in.
Thanks,
Dean
Old 12-31-2009 | 01:11 PM
OL40SVX's Avatar
Originally Posted by Dean Ferry
Cash,
Thanks,
Dean
The ZRC change was back in 2007. The ZR hasnt changed that im aware of.
OL40SVX is offline
Old 12-31-2009 | 02:39 PM
I am also looking for info on a Active Thunder that I am buying. Is all I know fro the mercruiser racing website is.
FEATURES
Integral hydraulic twin-ram power steering.
Built-in 7" setback.
Lengthened heavy-duty XR drive input shaft.
Trim and steering rams, multi-mounted to the gimbal ring, transfer load back to transom.
Built-in electronic trim & tilt with digital sender.
Rear drive cap features built-in tie-bar attachment.
Designed for Bravo One XR, Bravo One XR Sport Master, Bravo One XR Short Sport Master and Bravo Three XR drives.
dennis1009 is offline
Old 12-31-2009 | 04:55 PM
Cash,
Thanks,
Dean
I know what you thinking.. I called Craig about the same question.. he told me it makes no difference.. if the number is around what i told you go for it...
customryder is offline
Old 12-31-2009 | 04:59 PM
Dean Ferry's Avatar
Veteran: Air Force
CR,
Yes you do! Thanks for the info, I thought it would have made a difference in speed #'s/handling, especially in bigger water....... I KNOW it make a difference in the $$!!!!
And the # is getting close, real close...
Happy New year CR!
Dean
Old 12-31-2009 | 05:53 PM
Cash Bar's Avatar
Mod Squad Enforcer
Cash,
Thanks,
Dean
Wasn't trying to call you out. The ZRC was previously called a ZR.
That was part of the confusion when they added the new models.
And , if what you're thinking is near me, let me know if I can help.
Cash Bar is offline
Old 12-31-2009 | 07:42 PM
Dean Ferry's Avatar
Veteran: Air Force
CB,
No worries, you brought up good points. Thanks for the offer, I'm looking at a quite few 38ZR's, and one is in S. Fl. so maybe we'll get together if/when I come look @ it.
Happy New year.
Dean
Old 01-05-2010 | 03:49 PM
MarkDonzi's Avatar
thanks,
Dean
Hey Dean,
I just changed from a 38ZR with std Bravo XR's to 38ZR with 600's and latham extension boxes last season. Other than the speed and torque differences of the 600's the boat handles exactly the same. The ITS is a nice clean package on the transom, no hoses, etc to clean up around.
Good Luck,
Mark
MarkDonzi is offline
