Go Back  Offshoreonly.com > Owners Forum > Sonic
Hull Blueprinting >
Hull Blueprinting
Hull Blueprinting
Old 03-18-2010 | 09:16 AM
Plum_Crazy's Avatar
Default Hull Blueprinting
I never noticed this before, but I discovered my boat has about a 1/8" hook at the back of the hull. It's so uniform that I wonder if it was designed that way for planing and stability.
Has anyone had their 31SS hull blueprinted to get it perfectly straight? I'm considering this, but don't want to cause negative results.
Plum_Crazy is offline
Old 03-18-2010 | 12:36 PM
Plum_Crazy's Avatar
I finally received a response from Sonic...
"Dan,
Just spoke w/Bruce and that is an integral part of the design which
enables it to run smoothly w/different power options.
Lollie"
and
"Dan,
Bruce does not recommend doing so and he says with the 496HOs you're
probably going to get around 75mph max.
Lollie"
Well, I'm already at 75. But, I'm still curious if anyone has ever removed this hook.
Old 03-18-2010 | 11:46 PM
Z06
I thought when I straight edged my hull the very bottom center was straight and the hook was between the chimes and the rising strake. I didn't have the hull blueprinted but I did have a couple small gelcoat chips and some scratches filled. I then used a buffer and 3M finese-it II on the entire bottom to bring it back to new condition.
Your 31ss hull must still be like new given the speeds your running. Hope someone else chimes in on the blueprinting and/or removing the slight hook along with sharpening the transom to hull edge on a 31ss... I've considered the same.
Z06 is offline
Old 03-19-2010 | 08:52 AM
Hook and Rocker is the same as caster and camber and toe-in in a car. If you remove all the toe in and run straight up caster - camber your car will be faster but you will be chasing the car with the steering wheel, in others words it will be all over the place. Your boat will do the same. You need a certian amout of hook and rocker, I would think that depending on the hull type will depend on how much you might need. (Multi-step, single step no step).
45SS is offline
