Kaama exhaust question >
Old 03-25-2010 | 12:43 AM
bck's Avatar
bck
Charter Member#568
Default Kaama exhaust question
Anyone with a Kaama boat ever use aftermarket exhaust? What did you find fitment wise? I wanted to use the cast KE headers but was told they will not work with most boats that have a transmission. The exit angle of the headers is pretty steep and according to KE it only works well with a Bravo setup.
Straight bottoms and flat decks
bck is offline
Old 03-25-2010 | 09:36 AM
i have a setup from Kodiak with Imco ss risers that work fine. I know Lightnings will work. i don't see why KE wont? Stellings work as well. Here is a pic of mine.
Attached Thumbnails Kaama exhaust question-330s-010.jpg   Kaama exhaust question-p6200002%5B1%5D.jpg
Car Biz is offline
Old 03-25-2010 | 09:38 AM
Here is a Stellings setup looks like BIG$$$$$$$$$$
Car Biz is offline
Old 03-25-2010 | 10:08 AM
I redid a Fourmula with Kaama drives and Kaama motors years ago that had Gils on it Not a problem.
tommymonza is offline
Old 03-26-2010 | 05:23 PM
bck's Avatar
bck
Charter Member#568
The guy at KE said the their cast headers have a steep downward exit ( I think he might have said 32 degrees vs the usual 14) so the exhaust can get to standard height bravo exhaust opening. He said this can pose a problem when you move the engine forward with a transmission and can be further compounded if the engine is lower than a bravo installation. Basically seemed like the tail pipes might have to go up to exhaust outlets which wouldn't be good. I'm not sure how to post a link, but check out KE part # 755 8935 Notice the angle of the outlet and its height above the inlet ports.
http://www.keitheickert.com/detail.aspx?ID=7775
http://www.keitheickert.com/searchre...CategoryID=671
bck is offline
Old 03-27-2010 | 11:20 AM
hey jer were did you get that pic. bruce
BOATMAN302 is offline
Old 03-29-2010 | 01:08 PM
Off your buddys 357 he had i have another one too
Car Biz is offline
Old 03-29-2010 | 03:21 PM
bck's Avatar
bck
Charter Member#568
I remember when that one was for sale a couple years ago.
bck is offline
Old 03-29-2010 | 05:54 PM
I thought I recognized that engine compartment. Bruce
Old 03-30-2010 | 06:11 AM
I redid an 86 357 kamma and used stainless marine with custom long dry exhaust. Sounded great and will allow a bigger cam. I had stainless marine exhaust on that boat and a 90 292 bravo setup and had real good luck with them.
38fountainecman is offline
