Does anyone know this 2001 3o with twin 300x??
I am looking at a 2001 30 with twin 300x that is named Wet Kitty out of L.A. Califorina was owned by a guy name Alex. It is missing a prop and a lower unit and wanted to know if anyone has more info on boat good or bad.Frank
Nobody knows this boat? Then how much do you guys think a new lower unit will cost? How fast should it go with is setup?I have only seen a couple of the 30's run how do they handle,are they good boats?Frank
the 30 is a pretty good running boat. A conservative set up with 300x's should see 106 or so. you could probably get a bit more if you raise the motors a bit more and play with props. you just have to watch the water pressure
The nosecone should be about 1 1/2 inches above the bottom of the boat.
Check out screamandfly for a new gear case and prop. That's a really good setup.
