Go Back  Offshoreonly.com > Owners Forum > Spectre
Does anyone know this 2001 3o with twin 300x?? >
Old 03-30-2010, 06:43 PM
Default Does anyone know this 2001 3o with twin 300x??
I am looking at a 2001 30 with twin 300x that is named Wet Kitty out of L.A. Califorina was owned by a guy name Alex. It is missing a prop and a lower unit and wanted to know if anyone has more info on boat good or bad.Frank
DaBank is offline
Old 03-31-2010, 10:00 PM
Nobody knows this boat? Then how much do you guys think a new lower unit will cost? How fast should it go with is setup?I have only seen a couple of the 30's run how do they handle,are they good boats?Frank
DaBank is offline
Old 03-31-2010, 10:13 PM
the 30 is a pretty good running boat. A conservative set up with 300x's should see 106 or so. you could probably get a bit more if you raise the motors a bit more and play with props. you just have to watch the water pressure
obrien is offline
Old 03-31-2010, 10:49 PM
It has Power Lift on the motors.....I have never been a outboard guy but these are to move the height of the motors when driving the boat?
DaBank is offline
Old 04-02-2010, 01:41 PM
CMC Powerlift jackplates can be "manual" or "electric". I would bet yours are manual - meaning you physically set them when the boat is on the trailer. If you want to adjust them, you need to manually do so. The electric ones will move up and/or down at the flick of a switch, usually mounted on the dash.
The nosecone should be about 1 1/2 inches above the bottom of the boat.
mikesufka is offline
Old 04-03-2010, 12:59 AM
the jack plates on the 30's were manual ones. I know there wasn't one built with electric jack plates while I was there.
obrien is offline
Old 05-14-2010, 09:27 PM
dreamboater's Avatar
Check out screamandfly for a new gear case and prop. That's a really good setup.
dreamboater is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
