Older Gaffrigs >
Older Gaffrigs
Older Gaffrigs
Old 04-01-2010 | 09:36 AM
Default Older Gaffrigs
The Gaffrig gauges that have the built in warning lights....Did these have a feature that triggered a warning alarm built into them, or did you need separate sender switches to trigger the alarm?
MILD THUNDER is offline
Old 04-01-2010 | 09:42 AM
Same senders,light feature is build into the gauge
boatnt is offline
Old 04-01-2010 | 10:27 AM
I guess what i am asking is, to hook up a warning buzzer, is there a terminal on the gauge that will trip the buzzer in the event of a high water, oil temp or low oil psi.
Old 04-01-2010 | 11:37 AM
No, the red light is based on the guage reading and there is no terminal to wire an alarm off the guage.
Griff is offline
Old 04-01-2010 | 12:37 PM
Default Fixx
If your looking got a way to trip a buzzar use a coolent fan switch that goes into a coolent passage off of a older fwd car,they trigger around 220 deg, they also make a low oil pressure switch that goes off around 5lbs..
FIXX is offline
