gear lube reservoir-i am not sure if my boat should have one or not? >
Old 04-01-2010 | 11:33 AM
Default gear lube reservoir-i am not sure if my boat should have one or not?
this may seam like a really dumb question but i am not sure if my boat should have a gear lube reservoir or not? for those who have folloed my build at all, when i got my boat the motor was pulled and there was a pile of parts and no reservoir. the boat is a 89 baja sport 250, the upper unit and gimbal appear to be newer and i have a spare gimbal that came with it that i assume is the original. i have not noticed the serial number since it had new stickers on it.... the upper does NOT have the "oiler" vent tube on it, does that vent have something to do with it? on a another subject i need to plug that vent hole on the lower, does anyone know what size of plug i need to tap it for?
regalman4925 is offline
Old 04-01-2010 | 12:05 PM
blue thunder's Avatar
Measure the hole with a inside caliper. If memory serves me, the hole is just right to run a 5/16 nc tap in to. No drilling required. Use a SS set screw with red locktite. Just make sure you are catching the chips if the drive is assembled.
If you post a pic of the upper mounting surface to the bellhousing I can tell you if you have the reservoir drive or not. 1989 most likely not. 1988s did not.
blue thunder is offline
Old 04-01-2010 | 12:29 PM
Default Fixx
Alpha 1 no unless its a gen 2! Bravo 1 yes,,my buddy has a 89 235 dvx with a bravi 1,he has the older style one that looks like a tall olive jar thats held in with a spring
FIXX is offline
Old 04-02-2010 | 07:10 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Not all bravo 1 drives had reservoirs. The very year & first run of them did not have them!.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 04-02-2010 | 11:11 AM
Default Fixx
i agree jamie but most 89's did..
fixx
FIXX is offline
Old 04-02-2010 | 02:48 PM
fixx
Yes more of the 89's had is because the b1 actually showed up in 1988 boats.. Thats why I said the early ones did not have the res bottles.. Jamie
