Sea pump mounted fuel pump? >
Old 04-02-2010 | 02:14 PM
tssteph's Avatar
Default Sea pump mounted fuel pump?
when using the merc sea pump with the fuel pump mounted to it is there any option for a high performance fuel pump that will fit it?
tssteph is offline
Old 04-02-2010 | 05:54 PM
I got the KE billet lower from CP Perf a couple seasons ago, and it works fine so far.
Old Navy is offline
Old 04-02-2010 | 07:10 PM
As Old Navy said, the KE replacement unit is a nice piece. If your wish is to replace the entire assembly, well then it's time to break out the penny jar, err dollar jar, errrrr hundred dollar jar. CV products is pricey but the finest of the finest. Made for the Merc sea pump unit.
Attached Thumbnails Sea pump mounted fuel pump?-cv-billet-fuel-pump-001-1.jpg
ROTAX454 is offline
Old 04-02-2010 | 07:17 PM
axapowell's Avatar
Where To
I ran the KE product as well last season with NO problem.
Dave
axapowell is offline
Old 04-03-2010 | 12:25 PM
KEPP's Avatar
Only the Best Will Do!
Sure is.............http://www.keitheickert.com/detail.aspx?ID=939
KEPP is offline
Old 04-03-2010 | 05:53 PM
Why do you need more fuel...
Is greencard making you nervous?
bobkatz is offline
Old 04-05-2010 | 09:54 AM
tssteph's Avatar
just trying to simplify a little.
Greencard is and always will be faster then me
tssteph is offline
Old 11-11-2025 | 07:54 PM
Sorry for the old post resurrection.
Is the Keith Eickert the only option available for a sea pump mounted, mechanical fuel pump upgrade now?
The original plan was to use a block mounted fuel pump. (Baker style) I was told it didn't fit with the sea pump mounted, so we dyno tested it (made 600 HP) with the stock fuel pump installed. Obviously it worked, but I'm still nervous about running low on fuel.
It was recommended that I run 1/2" pick up tube in the tank. So I did.... Using AN -10 fittings and 5/8" hose to the water separator. Then AN -8 fittings and 1/2" hose to the fuel pump. The problem is, the fuel pump uses 1/4 NPT fittings IN and OUT.
It doesn't make any sense to me to run 1/2" or larger fuel hose to the pump, when it only has 1/4" opening. So I've been looking up old posts for upgraded sea mounted fuel pumps. CV no longer makes a marine version. And the KE pump seems to have mixed opinions on it's performance.
I'm not opposed to going electric fuel pump, I just don't know enough about them and wiring it up. It's easier to keep it simple and just replace the OEM with something that has larger openings and better flow.
My set up is the new GEN 5 block. It has all the benefits of GEN 5 with a block mounted fuel pump option.
502"
Quick Fuel 850 carb
BMP single plane intake
Promaxx 317" heads
MSD ignition
CMI headers
Thanks for any info you might have.
xlint89 is offline
Old 12-13-2025 | 07:45 AM
Active Streak: 30 Days
502"
Quick Fuel 850 carb
Promaxx 317" heads
MSD ignition
CMI headers
Fighting a similar issue. Mine keep leaking fuel into the sea pumps and blowing the seals. I am in the process of converting to electric but exploring all options first. I made a call to Teague yesterday and they said the merc pumps should not be failing and it is likely the fuel I am using is causing them to fail prematurely. I have no other symptoms of bad fuel, so I am not all in on that idea, unless ValveTech is corrosive to mechanical fuel pumps.
Helmwurst is offline
Old 12-13-2025 | 09:46 AM
SB
Side question, i’ve asked before an no takers - there are oils like vr1 and shaffers + others that are designed at holding a decent ant of fuel dilution and still do their job. Anyone use ouls like this vs gear oil for the sea pump mounted mech pumps ? I wonder if it would be better ?
SB is online now
