Mercruiser 330 Procharger Set Up >
Old 04-23-2010 | 11:50 AM
Default Mercruiser 330 Procharger Set Up
ANY ONE WANNA SHARE SOME INFO ON a good starting point for jetting, and fuel sys. setup
MEDIUMPIMPN is offline
Old 04-23-2010 | 11:52 AM
t500hps's Avatar
21 and 42 footers
a spare long block.....cause the Procharger is going to toast that non-mag 454.
sorry I can't help with any other info.
t500hps is offline
Old 04-23-2010 | 07:25 PM
I had a pair if prochargers on some 330's in my old baja. Go right to the procharger website get their phone number and call them for tech support. They want their stuff to work right even if you didn't get it from them. You won't be able to run a lot of boost with stock engines make sure your fuel pressure and flow are right (I had a problem with flow). If you do blow it up you have a great excuse to build a real engine. (-:
Sunshadow is offline
Old 04-23-2010 | 11:34 PM
Default thank for your response
im building a new motor right now, id rather use my stock motor for a test pig, i called pro charger and they were going to send out the info but, they must of had some communication problems, i only got the normal info in the mail, ill call agin monday. this is my first boost set up with a carb, so im kinda lost, thanks alot for your info.
jason
Old 04-24-2010 | 10:31 AM
many years ago i put a 8 71 on a stock 330.set it up for 5 lbs boost.i knocked the skirts off all 8 pistons the first time i gave it full throttle.those cast pistons cant take more than 3 lbs boost.i think you will be changing the engine
very soon.
mike tkach is offline
Old 04-24-2010 | 04:18 PM
very soon.
agree only 3 psi on that stock setup
Old 04-24-2010 | 11:08 PM
Default Fixx
what carb are you using? are you using a box (carb enclosure)or a bonnet?
FIXX is offline
Old 04-25-2010 | 09:44 PM
Running 82 primary 135 & 145 secondary , fuel cooler, 32 degrees total timing at 3500 . But that is also with a HP500 with a 741 cam , harden headers and pressure activated fuel regulators and real good fuel pumps . Plus a few hours on the dyno. good luck.
Jeff P31 is offline
