Ok got drive off....Videos included.... Whats wrong?
Sorry post with videos moved here http://www.offshoreonly.com/forums/d...ched-help.html
Just realized you have the drive off
There is a good video of it on the other thread http://www.offshoreonly.com/forums/d...ched-help.html
From what i am seeing, you haven't pulled the drive off the boat yet. The shifter cable in the gimble housing may be butchered up or even broken. You need to pull the drive off the boat to see if this is your problem.
I had a similar problem cable broke it would go in reverse but would not do anything else. You can switch the cable pretty easy back nuts off pull gear houseing back about 3/4 to 1" just enough room to see what is going on just make sure all o rings are in correct place after slinding new cable thru the cable bellows have a partner with you they are not heavy but not that light either
Go to you a manual called Seloc mercruiser stern drives it is like a hanes or chilton manuel gives step by step. Also a Mercury Mercruiser #28 service manual I have both very helpful on just about everything under the engine hatch Got mine on ebay but sounds like you need help asap
