Preload 1.7 Crane >
Preload 1.7 Crane
Preload 1.7 Crane
Old 04-27-2010 | 06:54 PM
glen george's Avatar
Default Preload 1.7 Crane
After reading everything on OSO, internet and looking through my factroy manuals I still have a question. Adjusting the crane 1.7 rockers 1/2 turn down after valve lash and the pushrod seats down between .020 to .060, the rocker arms on the completely closed valves can be wiggled by hand just a tiny little bit. The engine runs better than ever and the valve train is quiet. When the intake valve and exhaust valve are CLOSED and and the lifter has bleed down and the only pressure on the pushrod is the preload, there is still a little play on the rocker only in the closed position. Is that normal?
glen george is offline
Old 04-27-2010 | 07:16 PM
yes,when the engine starts,the oil pressure comes up,wala,no noise.
mike tkach is offline
Old 04-27-2010 | 08:10 PM
I ran the engine and there was no valve train noise, I did removed the valve covers and hand checked each rocker in the closed valve position and could wiggle each one slightly.
Old 04-27-2010 | 09:21 PM
glen,
That is completely normal with a hydraulic lifter.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 04-28-2010 | 01:28 AM
Normal.
Griff is offline
Old 04-28-2010 | 02:40 PM
Unlike most boaters that is normal.
Jeff P31 is offline
Old 04-28-2010 | 04:02 PM
thanks , glen george
