Stock Exhaust >
Stock Exhaust
Stock Exhaust
Old 05-03-2010 | 10:45 PM
mpally's Avatar
Default Stock Exhaust
We are looking to change out the stock Corsa exhaust tips on our 2004 36 Outlaw with 496's. The stock tips are not loud enough. What tips should we go with? How big of a project is this? I did a search, but most of the posts are rather dated. Any help is appreciated.
mpally is offline
Old 05-03-2010 | 10:48 PM
Can't you leave the tips and modify the mufflers or tips? It seems to me that if volume is all that you're looking for, you should be able to do it w/o changing the tips.
wjb21ndtown is offline
Old 05-03-2010 | 10:55 PM
I put Eddie marine tips on mine. It's not a hard job at all. It definetly made a big difference in sound. I would definetly do it.
sonic69 is offline
Old 05-03-2010 | 11:18 PM
Nightlife1970's Avatar
Just about any tip of the right size will work. If you have the Corsa tips I had you can drill out the rivits that hold the last baffel on and remove it. That makes a big difference in the sound.
Otherwise I just saw some tips that Irish got from Hardin. Nice looking tip that you can use the slip in silencers on. I don't think he spent a lot on them. I think mine are Eddie Marine tips, again if it is 4" exhaust any 4" tip will work.
Nightlife1970 is offline
Old 05-03-2010 | 11:51 PM
mpally's Avatar
Has anyone used these tips?
http://www.danamarineproducts.com/Pr...b-0d352a2e415b
Would these work in our application?
mpally is offline
Old 05-04-2010 | 04:33 AM
They should do the trick.
sonic69 is offline
Old 05-04-2010 | 03:33 PM
JasonSmith's Avatar
I prefer these by IMCO.
Attached Thumbnails Stock Exhaust-28515201663.jpg   Stock Exhaust-28515201747.jpg
JasonSmith is offline
Old 05-04-2010 | 04:37 PM
Never Enuff
I think if you buy the tips from Eddie, the flange on the new tips will not use the same holes as the Corsa tips. You will have to fill the old holes and drill new ones.
Jay
never enuff is offline
Old 05-07-2010 | 11:21 AM
i want mine to be louder too, but i can not see any type of silencer in the stock ones.
mittens is offline
Old 05-07-2010 | 12:04 PM
Corsa makes some very nice unmuffled tips with a clamshell internal flapper....much less clanging than most brands. That's what I'd go with and they're reasonably priced. It's an easy job; even I could do it. It's also a good opportunity to do a better job of sealing the wood in the holes than they did at the factory.
emilsr is offline
