Go Back  Offshoreonly.com > Owners Forum > Sonic
Trim & Tab cables >
Trim & Tab cables
Trim & Tab cables
Old 05-14-2010 | 05:15 AM
Default Trim & Tab cables
Hello all,
I'm new to the forum, just purchased a 2002 31 Sonic. Can't wait to get it in the water. Anyhoo, I need to replace the trim & tab cables. I've read several posts here on the subject full of great info. I'm looking for recomendations on what to buy for new ones, brands, part numbers if possible or specific model numbers. My current cables are marked as follows:
Ultraflex USA C0 FT15 211
C0 FT23 E29T
C0 FT20 341
C0 FT23 E29T
Thanks for the help,
Brian
Quinny is offline
Old 05-15-2010 | 11:45 AM
upstate31sonic's Avatar
Originally Posted by Quinny
Hello all,
C0 FT23 E29T
C0 FT20 341
C0 FT23 E29T
Brian
Welcome!!! to OSO
Never had to do anything with my cables so far...Hope that some one here can help you out and would love to see some pics of your new ride!!!
upstate31sonic is offline
Old 05-15-2010 | 03:15 PM
GO4BROKE's Avatar
I would call sonic or Dollar.
Sonic- 1-800-454-4245
Dollar 1-954-237-0332
[img][/img]
GO4BROKE is offline
Old 05-17-2010 | 05:17 AM
Thanks for the replies. Looks like I have bigger problems to deal with first. Dropped the boat in the water, fired her up, no water coming out the exhaust. I just replaced the impellers last week. Whats odd is that both engines did the same thing. Didn't take long to start heating up. I took apart the starboard side sea pump just to be sure the impellar was in right So know begins the fun eliminating possible plug ups. Going to start with the heat exchangers.
Quinny is offline
Old 05-17-2010 | 09:48 AM
Plum_Crazy's Avatar
Were pieces missing from the old impellers? If so, you need to backflush the system to get them out. Otherwise, make sure you put the water pump hoses on the correct locations. That's a common mistake.
Plum_Crazy is offline
Old 05-17-2010 | 11:00 AM
The old impellers looked fine. No missing pieces. Just routine maintenance. Hoses should be fine. I was able to change the impellers by just pulling the front of the houseing. Hopefully cleaning & backflushing the heat exchangers will do the trick.
Thanks.
Quinny is offline
Old 05-17-2010 | 11:14 AM
Plum_Crazy's Avatar
Did you buy the blue/yellow 31SS with the arch?
Old 05-17-2010 | 11:20 AM
No. Found this one down in Maryland. It was on Ebay. This one is yellow, orange & purple. No arch.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I just ordered a couple of the R&R rebuild kits from Grand Sport Center. Figure while I have everything apart again I would put them in.
Quinny is offline
Old 05-17-2010 | 01:11 PM
Plum_Crazy's Avatar
Nice! You don't see 31's for sale very often, at least not at a reasonable price.
Old 05-17-2010 | 06:51 PM
GO4BROKE's Avatar
If the housings are scored the R&R kits should fix it. I replaced my impellers for maintenance and 2 weeks later had low water pressure codes. fixed it with the R&R kits.
[img][/img]
GO4BROKE is offline
