24 Stepbottom Fuel Level Sender >
Old 06-02-2010 | 10:07 AM
jayhawk261's Avatar
Default 24 Stepbottom Fuel Level Sender
Where in the tank is the fuel level sender on a 2000 24 Stepbottom? My guys has been looking and looking and hasn't been able to locate it by eyeballing. Is it way up underneath the floor where it can't be gotten at?
jayhawk261 is offline
Old 06-02-2010 | 11:20 AM
Pat McPherson's Avatar
Yes.
Either live without a gauge or cut the floor.
Sorry,
Patrick
Pat McPherson is offline
Old 06-02-2010 | 11:22 AM
jayhawk261's Avatar
Why would they do that? I guess it needs to be in a specific place in the tank, but you'd think an access panel in the floor would be in order! Thanks for the info Pat!
Old 06-02-2010 | 12:29 PM
It may not be that bad.
The sender may be under the back seat. The seat comes out easily.
You can cut in one of those plastic inspection ports and it will be covered when you replace the back seat.
Time for a flashlight and tape measure.
Patrick
Old 06-02-2010 | 01:23 PM
I could have sworn on my 24 if you lifted the back seat cushion off, pulled out the storage insert, that you could see the sending unit for the tank. I thought it was glassed over and all that you could see was the metal connector that the wire connected to. I could be wrong, but thats what I remember it being like
elvisali is offline
Old 06-02-2010 | 01:36 PM
jayhawk261's Avatar
Does the back seat bolt in? I guess I haven't paid attention to that. I'll pass it on!
Old 06-02-2010 | 01:43 PM
You had an outboard. Right?
Patrick
Old 06-02-2010 | 01:45 PM
It is screwd to the floor and bolted to the side panels.
Patrick
Old 06-02-2010 | 01:59 PM
Yes, not familiar with the IO set up
elvisali is offline
Old 06-02-2010 | 02:50 PM
FX10's Avatar
Same tank, but is located further forward in the IO version. If you have a yard stick or something like that. You can slide it along the center of the tank till you come in contact with the sender. Then measure how far in you need to cut the hole. A inspection plate can be put over the hole. The outboard version had the sender under the rear seat storage locker.
FX10 is offline
