03 powerstroke overheats only when towing >
Old 06-02-2010 | 06:10 PM
Default 03 powerstroke overheats only when towing
My 03 f250 powerstroke runs perfect temp all the time till i tow something like a camper or my boat it then overheats clear up to hot and a red check guages lite come on. It just started last summer towing my boat i use a edge program on lowest setting but it has been on for 3 years, so i just changed the fan clutch and it did not help, coolant is full never loses any and clean as well. I still do not get the roar everyone else says they get from the fan clutch even with the new one. any help would be great.
rssteiny is offline
Old 06-02-2010 | 06:55 PM
I'll bet it's the fan clutch. Cheap and fairly easy DIY repair.
AngerMgmt is offline
Old 06-02-2010 | 08:02 PM
radiator clogged up inside or out water pump
firehawkcat is offline
Old 06-03-2010 | 06:53 AM
My suggestion is to first flush your cooling system. Then install an electric fan in front of radiator if still overheating.
Wannabe
wannabe is offline
Old 06-03-2010 | 07:32 AM
Did the fan clutch, no help
rssteiny is offline
Old 06-03-2010 | 08:23 AM
But, if you don't hear the "roar" of it engaging as the temp rises, it could be a bad one. That happened to me several years ago.......
Or, as someone else said, go with an electric fan.....
Most Edge tuners have a specific level for towing. On my Duramax, it's level 2. If you're on the lowest level, maybe you're running too lean......check your manual.
Old 06-04-2010 | 08:28 AM
DirtyMoney's Avatar
I had one with a bad water pump impeller. When towing it would slip on the shaft. There were no visible signs but pulled it and it was the problem.
DirtyMoney is offline
Old 06-04-2010 | 10:23 AM
Sick Stinger's Avatar
Brotherhood #1
6.0 7.3? if its a 6.0 its the EGR cooler when they go its lights out or the oil cooler same deal.
-Mike
Sick Stinger is offline
Old 06-04-2010 | 10:10 PM
could be the blue oval on the front
Old 06-05-2010 | 12:17 AM
buck183's Avatar
That's what I was thinking too. I had the very same thing happen to me on mine last year. Drove the tech crazy for a couple days until he figured it out.
Keep in mind this just after the head gaskets and egr had just been done.
Buck
buck183 is offline
