timing a 7.4 mpi motor
Old 06-08-2010 | 07:41 PM
Default timing a 7.4 mpi motor
i need some help timing my 2000 gen vi 7.4 mpi motor. i need to know how to set the base timing. i understand the timing should be 8 degrees as per the valve cover. i recently had the motor rebuilt and have it running pretty good as per setting it by hear.
ken3765 is offline
Old 06-16-2010 | 09:13 PM
wow no one can help, i am surprised
ken3765 is offline
Old 06-17-2010 | 07:07 AM
You need to jump pins A & B on the DTC connector to put the motor into base timing mode. Start engine and bring to 1500rpm, then set timing to 8 degrees.
ThruHull is offline
