J.c. Marine,,,496 Impeller Kit >
Old 06-18-2010 | 09:31 AM
Default J.c. Marine,,,496 Impeller Kit
can you still order there 496 raw water pump kits,,,are they still in business
TWIN-SPINS is offline
Old 09-21-2016 | 09:48 AM
JS232's Avatar
Did you ever found the info? Are they still in buisness? I need a good 496 pump rebuild kit. Thanks
JS232 is offline
Old 09-22-2016 | 12:49 AM
FWIW, I installed a aftermarket marine 496 rebuild kit in mine this spring. Nice kit and impeller. Impeller had same rubber consistency as a oem Merc going by feel. No problems after one season. Visibly more water out the tips vs 3yr old Merc impeller.
Ryan00TJ is offline
Old 09-22-2016 | 08:19 PM
JS232's Avatar
Thanks where did you get it?
JS232 is offline
Old 09-23-2016 | 12:56 AM
http://www.marine-496pump.com/index.htm
Ryan00TJ is offline
Old 09-23-2016 | 08:42 PM
JS232's Avatar
Did you have to machine the pump bracket? Or plug and play? Does it use a standard merc impeller?
JS232 is offline
Old 09-23-2016 | 11:02 PM
BUP
I would not advise using a 3 year impeller for any boat app. Even with zero time on it. They form a set while sitting. The impeller for the AM kit is shaved down a bit. Apples to apples it produces a bit of less water volume flow than new merc impellers with a good condition housing.
Also the kit does not remy any side wear nor any side scaring in the impeller housing. It is not uncommon to have side wear and or side scoring in these brass impeller housings especially boats without sea strainers. Also improper winterizations with water that freezes in the impeller housing can check them up internally. You can volume test for water output right after the impeller to make sure its within OEM spec.
BUP is offline
Old 09-24-2016 | 07:11 AM
JS232's Avatar
Bup, Any other known options? My housing has the scoring on both sides. Maybe i should just have the thing machined with brass...
JS232 is offline
Old 09-24-2016 | 07:56 AM
Hardin Marine has a nice stainless gen 7 kit. From what I've heard it worth every penny.
Ryan00TJ is offline
Old 09-24-2016 | 09:02 AM
I bought the Hardin stainless pump 4 years ago. It is a very high quality piece that can be completely rebuilt if needed.
underpsi68 is offline
