Fuel Syestem Upgrade? >
Old 05-02-2002 | 07:35 AM
OutlawMark's Avatar
Default Fuel Syestem Upgrade?
I AM RUNNING A GEN 6 502 WITH CANFIELD HEADS PUSHING AROUND 575 HP .IS THE STOCK FUEL PUMP AND FUEL FILTER OK WITH THIS SET UP OR DO I NEED TO UPGRADE TO HIGH VOLUME PUMP AND FILTER WITH BIGGER LINES??
OutlawMark is offline
Old 05-02-2002 | 08:35 AM
here are two formulas for you to figure cfm requirements first, then gallons per hour required. i don't know what your stock pump puts out or i would have done it for you. i would still go about 10% higher to be on the safe side. Fran
required air CFM =
engine cid X maximum rpm's
_______________________
3456
x volumetric efficiency
required fuel flow in gallons per hour=
air cfm x 4.38 x 0.08
____________________________
6lbs. per gallon
excaleagle42 is offline
beck427
Do It Yourself, Boating on a Budget
1
07-14-2008 11:14 AM
Rage
0
05-06-2008 11:00 AM
Viper TT
25
10-07-2007 07:05 AM
BillR
2
02-01-2007 08:54 PM
blue64drop
22
10-02-2002 03:14 PM
