Go Back  Offshoreonly.com > Owners Forum > Sonic
Fridge Issue >
Fridge Issue
Fridge Issue
Old 07-27-2010 | 08:35 AM
Default Fridge Issue
Having a problem with my fridge. Works fine while on shore power but once I disconnect it will not run off of the batteries. Anyone run into this problem?
Quinny is offline
Old 07-27-2010 | 09:25 AM
Plum_Crazy's Avatar
There might be a switch at the helm you need to turn on.
Plum_Crazy is offline
Old 07-27-2010 | 09:54 AM
HiPerf2000's Avatar
mine is on the "Galley Power" switch on the dash.
HiPerf2000 is offline
Old 07-27-2010 | 10:09 AM
I'll try it tonight with the "Galley Power" switch on & see what happens. Hopefully that does the trick. Thanks.
Quinny is offline
Old 07-27-2010 | 10:37 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There is often a fuse/circuit breaker on the back of the fridge itself. This may have tripped on you as well.
Sydwayz is offline
Old 07-27-2010 | 06:26 PM
upstate31sonic's Avatar
"Galley Power" Works for me too!
upstate31sonic is offline
Old 07-29-2010 | 04:37 AM
Well the Galley Power does make it turn on, or at least some noise comes from the fridge for a minute then nothing. I pulled the fridge out. Fuse on back looked fine but going to replace to to eliminate that as a problem.
Quinny is offline
Old 07-29-2010 | 09:21 AM
Plug up the shore power and turn on the battery charger, turn on the fridge overnight and see if it remains cold. This way you won't hurt the batteries.
45SS is offline
Old 08-06-2010 | 08:57 AM
last year I installed a brand new norcold db0751. It worked fine for 1 year. Now it only runs on a/c. I called Norcold and was told to take it one of their agents. They offered no repair advise. The fuses at the top and rear of the fridge are fine. I did'nt want this thread to die without solutions. I'll post mine when I have one.
captain caveman is offline
Old 09-24-2010 | 08:04 PM
Perfect Storm's Avatar
I went for a ride on the sonic with the captain last week... great ride!!! BUT, next time I'm definitely bringing my own cooler and beer because his f#/*ing fridge was STILL broke!
Perfect Storm is offline
