Merc 496 Crate Motor
Old 08-02-2010 | 09:43 AM
Default Merc 496 Crate Motor
Guys - I'm hoping you can give me some much needed guidance. I bought a Cobalt 360 3 weeks ago. On week two - at startup I threw a rod. Oil levels were perfect, motor has 460 hours on it. The motor is a 2003 TPI.
Last week I bought a merc crate motor (rebuild) and dropped it in. Can someone explain to me how to set the motor for startup? Do I have to worry about timing / top dead center. The crate motor was a long block with tin and a water pump.
I turned the key on - power to the fuel pump - no power to the coils. Cranks over fine, but won't start due to lack of spark. Any suggestions would be appreciated!. ..
downtime270 is offline
Old 08-02-2010 | 01:17 PM
Wobble's Avatar
SORE MEMBER
It could be a
1/ ground problem
2/ harness or sensor unplugged somewhere.
Wobble is offline
Old 08-02-2010 | 04:25 PM
First thing I would check is the kill switch. Both ends.
Skullkrusher is offline
Old 08-02-2010 | 04:45 PM
seafordguy's Avatar
Agreed - been there before....
seafordguy is offline
