how do you remove a bravo drive >
Old 08-06-2010 | 06:42 AM
Red face how do you remove a bravo drive
When trying to take off a bravo drive do you have to put the shifter in forward.Help please what else do i have to watch out for.
sonic28 is offline
Old 08-06-2010 | 07:16 AM
Knot 4 Me's Avatar
No. When you pull the drive off it will pull it into gear before the jaws let go of the cable. Just remember to unhook the speedo pickup before removing the drive.
Knot 4 Me is offline
Old 08-06-2010 | 07:17 AM
Ted G's Avatar
Not really. Once you pull the nuts all loose, carefully pull the drive back. As you do the shift cable will pull the lever from the drive and expose the end, lift the little plate on top of the lever and pull the cable free. Then slide the drive the rest of the way out. When you go back on, just make sure the cable drops back into the lever before you push the drive all the way home.
www.cbpba.com
Ted G is offline
Old 08-06-2010 | 08:21 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
just remember the hidden bolt on bottom of cavitation plate
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 08-06-2010 | 08:50 AM
t500hps's Avatar
21 and 42 footers
You guys have it all wrong...fill a cooler full of beer and use the phone number of a couple buddies that have done it before. Once they arrive, in 10 minutes the drive will be off, you will have seen how it's done, then you can BS for 4 hours while you drink all the beer.
(and the best part is you can tell the wife you were working on the boat all afternoon!!!)
t500hps is offline
Old 08-06-2010 | 08:53 AM
i think he is refuring to takeing the drive off the gimble,no need to split the lower from the upper for that
mike tkach is offline
Old 08-06-2010 | 08:56 AM
T500HPS,i like the way you think,even better if you tell your buddys to bring some cold beer.
Old 08-06-2010 | 09:13 AM
Last time i took mine off i had shifter in forward position, tac@5100, mph 74-76, came off rather easy when i hit a submerged log at cumberland, damn near threw me over the handle bars
srx 780 is offline
Old 08-06-2010 | 01:15 PM
anewway's Avatar
Well, that's one way to do it.
anewway is offline
Old 08-06-2010 | 01:22 PM
thanks guy's now i know except I have a better idea watch five girls drinking beer while they take it off.The drive i mean .serious thanks guy's
sonic28 is offline
