2 batteries? >
2 batteries?
2 batteries?
Old 05-05-2002 | 11:14 PM
crmax's Avatar
Default 2 batteries?
I have a 20' wellcraft with a single battery , do I need a dual batt setup? I only turn on the radio for an hour max with out the motor running
crmax is offline
Old 05-05-2002 | 11:20 PM
Audiofn's Avatar
Charter Member #232
Well that depends. You are probably ok with just one. If you see your boat becoming hard to start or not starting then you will want to think about adding one. I am not sure what your stereo consists of but if it is just a head unit then 1 hour of not running is NO problem at all.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-05-2002 | 11:32 PM
mcollinstn's Avatar
a battery buddy will click to off when the battery voltage drops below 11 volts (I think). You can press the rest button and have enough juice to start the motor.
mcollinstn is offline
Old 05-05-2002 | 11:35 PM
crmax's Avatar
just the basic head no amps, havent even stayed out late enough to use the ancore light, I just think it would be over kill but I may be wrong if it doesnt start one day
crmax is offline
Old 05-05-2002 | 11:37 PM
crmax's Avatar
I like the batt buddy idea, its rack stored so it doesnt matter if the bilge pump doest get power for a few days if something went wrong
crmax is offline
Old 05-06-2002 | 09:35 AM
Audiofn's Avatar
Charter Member #232
Yup the Battery Buddies work well and they came out with a Marine version last year or the year before. Good choice for the single bat. boat.
Jon
Audiofn is offline
Old 05-06-2002 | 09:54 AM
29Fever
Just get a jumper box from Walmart. Throw it under your hatch and you won't have to worry about it. That way you don't have to mess with wiring two batteries, getting another box and switch. Not to mention the battery itself.
Old 05-06-2002 | 10:29 AM
BajaBoss252's Avatar
Don't put the jumper box under the hatch if you have an electric hatch lift as I do, or it won't do you any good. If you can't open the hatch to get the jumper box out, you can't jump start the boat....
BajaBoss252 is offline
Old 05-06-2002 | 05:57 PM
crmax's Avatar
i like the jumper box idea also, maybe Ill do both
crmax is offline
96f350psd
13
01-18-2009 07:14 AM
teamsynergy
04-13-2008 09:45 AM
Courtholl
Pantera
12
03-05-2007 04:26 PM
bluewater7
0
08-31-2005 01:14 AM
