Trim indicator cables >
Old 05-06-2002 | 11:27 AM
blown formula's Avatar
Question Trim indicator cables
Can trim indicator cables be lubed??? One of mine appears to stick as one ram will not follow the drive past 6 on the indicator. I can pull the ram out, so it does move. Can this be cleaned & lubed or must the cable be replaced?
blown formula is offline
Old 05-06-2002 | 03:12 PM
Tinkerer's Avatar
I to have that problem and no youy cant lube them just replace them as I will soon do.
Tinkerer is offline
Old 05-06-2002 | 06:31 PM
Don't know if it will work on these cables but we use to on the motorcycle cables we would take ziplock bag cut little hole in bottom corner insert cable tape it back real good put some light oil in and hang it higher than the outher end overnight!James
FloridianSon is offline
Old 05-06-2002 | 08:48 PM
Tinkerer's Avatar
Thumbs down
I tried to lube mine. how I lube cables is to remove all hardware from the end and clamp a short piece ( 1 ft ) of fuel line to the end covering all the way up to the plastic part. Then I pour in the lube of choice and then clamp the other end to an air line and turn on the air--- blows the lube through the cable. But not with the indicator cables--they are sealed. NOTE push the lube in at the dash end-- don't push the dirt further up the cable.
Tinkerer is offline
Old 05-06-2002 | 09:27 PM
thespy's Avatar
I just replaced all 4 , trim / tab cables on my cigarette, they rust, most of the time the rust is on the outside exposed part, the best prices I found for 33c supreme. 21-25' was $65 at Boat owners warehouse in South Fla. It took about 4 hours to put all the cable in, I taped the new cable to the old one and pull it through.
thespy is offline
GoFastSonic
Sonic
4
08-05-2008 10:52 AM
powerquest280
Sonic
6
04-14-2008 08:03 AM
PARADOX
3
08-28-2007 10:55 AM
mjb
Cigarette
27
08-13-2007 08:45 AM
blown formula
05-07-2002 03:37 PM
