Question For Jo >
Question For Jo
Question For Jo
Old 09-15-2010 | 01:56 PM
bigboat28's Avatar
Default Question For Jo
Jo I have another one or your boats. We used it last weekend and are probably done for the year. While running I have to run the tabs at a little over 3 to stop the porposing, that is at a cruising speed. I think it is over propped some because I am only able to turn around 4200-4300 rpm and I am guessing from what Neversatisfied said that at those rpm's I am doing between 70-75 ish. He was running beside us. I don't know what size props they are yet because I have not been able to get them off. Previous owner said he never took them off. Anyways, Jo any ideas on getting it to stop porposing so bad? I am planing on atleast a new back seat this winter, and a cover, maybe a whole new interior. It also needs some carb work.
bigboat28 is offline
Old 09-15-2010 | 02:53 PM
bigboat28's Avatar
Jo could you pm me a price on a fiberglass windscreen?
Old 09-15-2010 | 03:50 PM
Ditto on the windscreen.
Viperchad is offline
Old 09-15-2010 | 04:01 PM
IRONMAN's Avatar
I would be interested in a new style factory windscreen / fairing also.
IRONMAN is offline
Old 09-15-2010 | 05:01 PM
JO - PANTERABOATS's Avatar
Hi Dale,
I am glad you purchased another Pantera 28' Twin. My Father sold your 28' back in 1986 as a hull and deck only with upholstery and hardware. He did not rig it. I was 15 years old at the time so I do not have much info. to offer you.
I would need to see pictures of your set up and props to give you better advice. Are the props spinning in or out ? Does it do it when the drives are tucked in all the way or when trimmed ? How much fuel was in the tank ?
When you deal with speedmaster drives and props the set up is quite different than Bravo 1 drives and 4 blade bravo 1 props on your other Pantera 28'. It seems to me that your RPM is down from where it needs to be.
Call Dave at MDG Performance in Maryland since I think he worked on that 28' of yours while stored at his Marina. Dave is a very experienced engine builder with many years of experience.
JO
JO - PANTERABOATS is offline
Old 09-16-2010 | 10:58 AM
bigboat28's Avatar
Jo, it does it wether drives are in or out. The props are spinning out. The higher the rpm the less tab needed, and I understand that. The tank was full when we started. I was just wondering if there was something I could do to not have to use so much tab at lower rpms?
As far as rpm's being down, I think the props might be a little big. The motors were checked out and were fine with 150lbs on every cylinder.
Old 09-16-2010 | 02:43 PM
fantastixvoyage's Avatar
bigboat - add more power!
Not even kidding. I think that combo needs a bit more power to run right. The hull is trying to work but doesnt have the umph to get there. In the meantime grab a real small set of props just to let the motor buzz up a bit easier. Should change the attitude of the boat a bunch. Just my .02.
fantastixvoyage is offline
Old 09-16-2010 | 03:26 PM
bigboat28's Avatar
My props are 15 3/8x 26. I would like to add some power evdentually.
Old 09-16-2010 | 06:50 PM
Did you get yhem off?
NEVERSATISFIED is offline
Old 09-18-2010 | 03:28 PM
bigboat28's Avatar
Jo you have a price for a windscreen yet?
