How to slow down
Old 09-17-2010 | 10:57 PM
Default How to slow down
What is the best way to slow down from 60+mph when approaching a boat wake or some rough water? It is best to pull back on the throttle quickly? Or trim the drive down deeper into the water? Or put the trim tabs down? I would like to slow down quickly without putting extra strain the on boat/motor/drive. FYI, Boat is a 25ft I/O with 454 and Bravo 1. Thanks.
Ultraboy is offline
Old 09-18-2010 | 01:42 AM
Trim and tab it down a little and then pull back on the throttle just as you hit the wave. Fly off the wave and back onto the throttle.
Griff is offline
Old 09-18-2010 | 10:00 AM
Are you talking about slowing down to roll over the wave or jump?
Its best slow down normally. Chopping the throttles and putting it back down is more strain than having to plan off again.
Mastercraft240 is offline
Old 09-18-2010 | 10:11 AM
Wobble's Avatar
SORE MEMBER
I always de-throttle and trim down at the same time. Not sure if the trim angle helps the braking, but I do it to have the correct position for getting back on the power.
Wobble is offline
Old 09-18-2010 | 10:14 AM
And by surface drive?
sinus is offline
Old 09-18-2010 | 10:16 AM
Velocity Vector's Avatar
Crazy Energy
I wouldn't try it this way.
http://www.youtube.com/watch?v=C0KmGfBCJtQ
Velocity Vector is offline
Old 09-20-2010 | 03:53 AM
articfriends's Avatar
When I'm running over 90 I back off the throttle slooooowly and start dropping drive back in but not too fast so boat doesn't bow steer , but at sane speeds I just pulll back the throttle and dig drive in,Smitty
articfriends is offline
Old 09-20-2010 | 07:57 AM
I say just buy an Apache. Generally, I accelerate into oncoming bumps and only cut the throttle if props break the surface.
baywatch is offline
Old 09-20-2010 | 03:15 PM
Big Daddy is the man! Look at him pimping Super Shops also.... Good ole days.
ckin62 is offline
Old 09-20-2010 | 03:21 PM
lol "hey big daddy, are you ok?"
"my feelings are hurt a little..."
panicrev is offline
