mercruiser pulley >
mercruiser pulley
mercruiser pulley
Old 05-08-2002 | 11:15 PM
Big Block Billy's Avatar
Unhappy mercruiser pulley
I need at least one Merc. circ pump pulley for 454. It is part # 19692 3 groove steel apx 7" . I found a replacement from ebasicpower.com, but it is 6" . Does anybody know where to get these from. I can get all the other pulleys from Mercruiserparts.com but this one is not availiable. Around 88 Mercruiser changed their pulleys. The newer arrangement had an aluminum crank pulley, Alum seawater pump pulley, and a 3 groove Circulating pump pulley. I like to use the newer setup because the old steel crank pulleys all rot out. I will be building several motors in the near future and would appreaciate it if I could get any of these pulleys. The crank pulley is # 90081-C. Seawater pump pulley is # 52822-C . Thanks,
Big Block Billy
Big Block Billy is offline
Old 05-09-2002 | 12:08 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Did you try pt# 19692P from Mercparts? It still shows good.
US1 Fountain is offline
Old 05-09-2002 | 08:43 AM
I tried by motor # and the part showed but was grayed out,
Mercruiserparts showed a price over $300, but it was not currrently avail. Maybe if I use the number in the search I'll have better luck. Thanks, BBB
Old 05-09-2002 | 05:22 PM
Strip Poker 388's Avatar
Rob
i think i have one off a 1989 365 mag,let me know
Strip Poker 388 is offline
Old 05-09-2002 | 05:48 PM
Ginger or Mary Ann?
Naw, that ain't right. Try again .........Item #14,
http://www.mercruiserparts.com/Show_...ND+FRONT+COVER
Old 05-09-2002 | 10:06 PM
Thanks US1 Fountain ! I typed in the number you gave me and it came up. Only $61 ! How cool is that. I'll be making my order tomorrow. Thanks again, BBB
Old 05-10-2002 | 12:24 AM
Ginger or Mary Ann?
Your more than welcome.
Old 05-12-2002 | 12:24 AM
red racer
Lightbulb
Just a thought...
I still have my original pulleys for this engine. I took a look at them through the dust to find the following part #'s:
Waterpump: Steel 7"
Sea Water: Alum. 5 5/8" #52822-c
Crank: Alum. 6 3/4" #90081-c
Alternator: Steel 2 3/4" w/ fan
I ended up moving into a set of Alum. last year and couldn't see throwing away anything good.
If you have a contact to get rid of these or a set of manifolds, risers, "Y" pipe, distributor, I would be appreciated. I would like to get them to someone that can use them...
Thanks, Tim
Old 06-15-2008 | 04:07 PM
Red Racer, do you still have the 90081-c?
icemanruss is offline
Old 12-12-2009 | 06:35 PM
Where did you get your alum pulleys from Im going threw my motor and need the whole set.
bwammack02 is offline
slik22
Swap Shop
0
10-25-2008 07:40 PM
BERTRAM BOY
Wanted
4
05-15-2008 03:30 PM
poolshrk
04-06-2008 11:34 AM
Racerngr1
09-09-2007 08:38 AM
CHAOS REIGNS
8
04-11-2004 07:52 PM
