Engine Build Finally Under Way!! >
Old 09-27-2010 | 05:28 PM
Default Engine Build Finally Under Way!!
here are some pics of the short block going together. i shoulda got off my ass and done this before the season was over but i guess now i can take my time this winter and make sure all is good.
Attached Thumbnails Engine Build Finally Under Way!!-boatengine1.jpg   Engine Build Finally Under Way!!-boatengine2.jpg   Engine Build Finally Under Way!!-boatengine3.jpg
Engine Build Finally Under Way!!-boatengine4.jpg   Engine Build Finally Under Way!!-boatengine5.jpg
87MagnumII is offline
Old 09-27-2010 | 06:10 PM
and a few pics of the boat its going in
Attached Thumbnails Engine Build Finally Under Way!!-123.jpg   Engine Build Finally Under Way!!-sideview.jpg
Old 09-27-2010 | 08:06 PM
Rookie's Avatar
What other Goodies are going on that short block?????
Rookie is offline
Old 09-27-2010 | 08:19 PM
its a 1997 350 cui SBC and its getting
Vortec heads
performer rpm intake
the pistons are 9.8:1 forged flat tops
the block was decked
and here is a link to the cam kit im using:
http://sdparts.com/details/gm-perfor...parts/12480002
ive been told it should be around 380-400hp
im still undecidied about a carb tho,im thinkg i should stick with a 650 but a 750 still lurks in the back of my mind altho it may be to much
Old 09-27-2010 | 10:12 PM
I would say the 750 cfm would be to big but im no expert
firehawkcat is offline
Old 09-28-2010 | 09:15 AM
fireboatpilot's Avatar
RIPSTA Racing Team
I'm no expert either but I would check those cam specs up against some other marine cams and see if the duration and overlap are good for a marine application. Mabe contact one of the cam guys here on OSO. I might also consider using the Edelbrock carb to go with that intake. Just some thoughts. I know marine cams are different designed than cars.
fireboatpilot is offline
Old 09-28-2010 | 06:54 PM
Ive talked to a few people that have used this cam in boats with great results. i have also looked at a few marine cams with close numbers to the one im using so im crossing fingers and hoping they are right.
Old 09-29-2010 | 08:13 PM
assembling heads tomorrow, more pics to come
Old 09-30-2010 | 09:01 PM
i have pretty much the same set up in a 21fter and a 650 carb works perfect good luck
innerrage is offline
Old 09-30-2010 | 10:45 PM
thanks for the support!! how does it run?? what carb are you using?
