Engine Alignment Tool Part Number >
Old 05-11-2002 | 11:09 AM
blackhawk
Default Engine Alignment Tool Part Number
Does anyone know the correct part number for the engine alignment tool for Bravo gimbal and 502 engine(1995)? I was told it was 91-805475A1, which I purchased. But the end does not fit into my engine coupler.
Old 05-11-2002 | 05:42 PM
blue thunder's Avatar
Do a search of past threads on this site on alignment or engine alignment. You'll find everything you need to know, including dimensions to make your own tool.
BT
blue thunder is offline
Old 05-11-2002 | 09:52 PM
Mbam's Avatar
Offshoreonly Advertiser
That's the one and only tool. If you are checking with the engine in the boat, sounds like the alignment is pretty far off.
Mbam is offline
Old 05-12-2002 | 05:06 PM
Question Engine Alignment Tool Part Nr.
Hi Blackhawk
I`v got the same problem with the same tool,
is it the meaning for the tool to go all the way
inside the coupler splines?I`v tryed on 2 of my
couplers loose,but it stops on the splines,it`s
too big and thats it.No, I`v on 4 couplers.
502 Magnum
502 Magnum is offline
Old 05-13-2002 | 05:00 PM
Default Alignment Tool
No reply on this one?
502 magnum
CULATER
Ft Myers Offshore
4
03-14-2008 11:10 AM
Ken N
4
10-25-2007 09:46 PM
ofshore
33
04-06-2007 06:32 PM
tmdog
11
03-27-2005 07:52 PM
blackhawk
05-13-2002 07:29 PM
