what rpms should i run??? 540ci NA..... >
Old 12-08-2010 | 05:12 PM
Default what rpms should i run??? 540ci NA.....
chevy std deck 540 started as 502
8:1 comp
iron gm rect heads same as HP500
isky springs
victor jr intake
holley 850
lunati 50250 cam here is the cam card.....
http://www.lunatipower.com/Product.aspx?id=2104&gid=264
changing drive height and props, so i can prop it wherever. where do you engine gurus think it will make the most power????
302Sport is offline
Old 12-08-2010 | 05:53 PM
Ran-Dom 32's Avatar
Ran-Dom 32 is offline
Old 12-08-2010 | 06:27 PM
In my setup what is going to hit a wall first, the cam or the carb
302Sport is offline
Old 12-08-2010 | 06:46 PM
IMHO that cam is a poor choice for a 540 ci N/A engine. The bigger cubic inch engines like a wider LSA like 112 - 114 and I would increase the duration and lift. Those heads will support .650 lift with mild work, it would be nice to add compression but not a requirement. I also would spread the intake and exhaust duration, adding 6 -8 degrees of exhaust duration to the intake duration. You should contact Bob Madiera of Marine Kinetics 585-654-8583, you won't be dissapointed.
Boat1 is offline
Old 12-08-2010 | 06:52 PM
In your guys opinion how much HP will I see with just a dif cam? Don't care how it idles and I have dry exhaust so don't have to worry about reversion
302Sport is offline
Old 12-08-2010 | 07:11 PM
The only way to know for sure is to run it on a dyno !!!!!
Jeff P31 is offline
Old 12-08-2010 | 07:19 PM
OK I'll let everyone beat me up for my opinion but here goes: I'd use a 236/244 duration @ .050 on a 114 LSA with .640 - .650 lift both sides, Intake centerline about 110 degrees. Do all port work on the exhaust side of the heads, at least bowl/pocket blend. I'd estimate this combination to be 630 ft/lbs torque @ 4600, and 630 HP @ 5500 rpm. I've done many 540 engines but better heads and 9.2 compression, I use 240/248 @ .050 w/ 114 LSA and .680 lift. They make 680 ft/lbs torque @ 4800, and 675 HP @ 5800. Again, if your going to spend the money anyway, call Bob.
Boat1 is offline
Old 12-08-2010 | 07:23 PM
Not going to dyno this winter......heads are at the shop right now and can pull cams out but that's as far as I'm going this year
302Sport is offline
Old 12-08-2010 | 07:28 PM
I have my own guy who does some cup car stuff. I will listen to madera and let him grind me a cam but other than that I want my guy to do the work. He has talked to eickert and built some of his motors. He told me he isn't in the marine business so if somebody who builds boat motors for a living tells him how to do it he is all ears
302Sport is offline
Old 12-09-2010 | 07:03 AM
Registered User
Default cams
i have two of bobs cams hyd roller 112 lob sep 234/240@50 611/596 lift 200.00 each form 540s
itbs is offline
