what rpms should i run??? 540ci NA..... >
Old 12-11-2010 | 01:34 AM
  #61
jeff1000man is offline
Old 12-11-2010 | 01:59 AM
  #62
What's the popcorn for?????? You been at the local cinema all night????
302Sport is offline
Old 12-11-2010 | 08:20 AM
  #63
Wow. I cannot imagine going through all of this and no dyno. Can you tune two at a time in the boat? Do you have O2 sensors in your headers?
TxHawk is offline
Old 12-11-2010 | 09:54 AM
  #64
He finds the thread entertaining. After you talk to Bob on Monday you will have a new insite on cams. I went through the same thing you are doing now. I talked to all the so called tech lines and then "wow", I talked to a real expert.
jeffswav is offline
Old 12-11-2010 | 10:27 AM
  #65
most likely i will dyno them..........
302Sport is offline
Old 12-12-2010 | 01:32 PM
  #66
Velocity Vector's Avatar
Crazy Energy
I have a pair each of cams/Brodix intakes/1050's Deamons that came off of my 509 635 HP supercat engines W/9.3:1. I beleive cams are .720"/.720" lift....272/282 @ .050 with a 108 lobe sep.
I added 3.3 whipples.
Velocity Vector is offline
