AN hose sizes for cooling.
2 Quick questions for the masses:
1) What size (-AN) do people normally run for hoses from T-stat to the Exhaust (CMI) distribution tube. and
2) What size fitting is on the end of the distribution tube. Looks like 3/4" to me but what thread are they normally? (NPT etc)
Thanks in advance!!
Thanks in advance!!
How do you go from the T-Stat housing with about 22mm diameter on the outlets to the AN hose (-12) if it's ~18mm? Or do you need to modify the t-stat housing for an AN fitting (weld on?)
My current hose is 22mm ID (AN-16?), would reducing it to -12 possibly result in an increase in water pressure? If so, where is the best place to plumb in a pressure dump? I'm thinking of the ports at the back of the intake manifold into a T then dumping overboard. Any other suggestions?
http://www.eddiemarine.com/store/car...l&p=11552&c=40
Should be 3/4" npt on the exhaust distribution tube. Check with CP Performance. They have some SS fittings that are 3/4" npt X 1" hose barb.
Also, the OD of the 3/4" npt fitting is right at 1". I have used jsut a 3/4" npt nipple and slipped the hose on it in a pinch. The threads actually do a good job of giving the hose something to bite into.
Eddie
Eddie
