SHE RUNS!!, but... >
SHE RUNS!!, but...
SHE RUNS!!, but...
Old 05-16-2002 | 11:41 AM
Smile SHE RUNS!!, but...
got it running bad h2o pump, carbs were gummed up pretty bad. but all in all it looks good.
however, when i gun it every now & then it backfires thru the exhaust, i’m thinking timing. the linkage for the mechanical advance looks new and none of the adjustments for it were tight. any one have an idea what the base timing and total advance should be? i’m familiar with the merc. 4-stroke stuff (34* total), would this be similar? or am i way off? any help is greatly appreciated.
oh, and i was wrong in my fist post, it’s a DT-140 not a TC-140, if that maters.
thank you,
dean campbell
dean campbell is offline
Old 05-16-2002 | 04:05 PM
mjuwalters
Dean you would need to check a manual but the timming at idle would be close at about 4or5 degrees AFTER tdc total would be something like 17degrees befofe tdc. Sorry I don't know the exact numbers ITS been a while since i've worked on suzukis
Old 05-20-2002 | 10:26 AM
Audiofn's Avatar
Charter Member #232
Get the Merc Manual and do it right. If you go to far with it you will blow her up. Also make sure that all your bleeder hoses are connected to the correct area and none of them have cracks in them.
Jon
Put your best foot forward!
Audiofn is offline
skaterjim
03-03-2006 11:08 AM
jeff32
12-29-2005 01:33 AM
dreamer
04-11-2005 05:32 PM
Maximus
02-12-2004 07:59 AM
klaw
07-10-2002 03:09 PM
