Edelbrock carb >
Edelbrock carb
Edelbrock carb
Old 01-24-2011 | 12:49 PM
Default Edelbrock carb
Anybody running an ebrock carb? I have a 88 rinker 206 with a new longblock going in 350ci, and i'm going from the 320 efi setup to an ebrock aluminum intake and carb. should I be looking at 600 or 750 cfm? anyone with similar setup?
88 206 is offline
Old 01-25-2011 | 07:04 AM
I run a pair of them on my 454's in my gibson, work very well, I only run the 600's as the engines never see 4000, if you turn the normal 44-4600 run the 750's
ezstriper is offline
Old 01-25-2011 | 08:07 AM
Thats good to hear, hows tuning? easier than Holley?
88 206 is offline
Old 01-25-2011 | 10:16 AM
I run Edelbrock on all of my motors. Easier to tune, tougher all around, no joints below the fuel level, simple rebuilds.
f_inscreenname is offline
Old 01-25-2011 | 11:13 AM
so I'm guessing the 600 cfm would be best for otherwise stock 350 ci?
88 206 is offline
Old 01-25-2011 | 11:57 AM
600 is plenty for 350. I have used them on small blocks they work well, make sure you get the marine version.
1BIGJIM is offline
Old 01-25-2011 | 12:07 PM
Yes I am aware thanks.
88 206 is offline
Old 01-25-2011 | 11:30 PM
Yep.
Griff is offline
Old 01-26-2011 | 05:41 AM
I also run Edelbrock 1409 on my 350 89 Wellcraft. No issues easy to work on and hassle free.
motorz is offline
Old 01-26-2011 | 02:44 PM
Might add to get the needle kit as it makes it easy to change out the fueling. I have the 1410/750cfm. I don't think it's enough for my 509.
You can never have enough fuel unless you're on fire.
high bid is offline
