496HO Alarm Problem Fixed >
Old 05-20-2002 | 08:06 AM
wms
Question 496HO Alarm Problem Fixed
Posted a while back asking if anyone had ever experienced a two beep alarm at approximately 1 minute intervals. Got no responses. Well, it was finally diagnosed as a bad oil pressure sensor. The error code was forcing the engine into a 90% power mode, thus the alarm. A new sensor was installed on Friday and she ran alarm free yesterday just in time for the long weekend.
But I have a question for you guys since this is my first twin engine boat. The same engine is still running 100 rpm less. It has from day one (35 hours ago) even before the alarm issue. In cool dry air yesterday I got 4950 on the starboard engine and 4850 on the port. Is this normal and acceptable?
Macklin
Old 05-20-2002 | 09:35 AM
Mine have been off by about 100rpm since day 1. I just attribute it to the tachs.
29 OUTLAW is offline
Old 05-20-2002 | 02:52 PM
Tinkerer's Avatar
Cool
Is the slow engine the one with the power stearing pump. If it is that is usually the cause.
Tinkerer is offline
Old 05-20-2002 | 03:43 PM
wms
Yes, as a matter of fact this subject came up at the beach yesterday as a possible cause. I still do not fully understand why there is a need for a power steering pump and reservoir when the boat has full hydraulic steering.
Old 05-21-2002 | 06:58 AM
Mbam's Avatar
Offshoreonly Advertiser
100 RPM can easliy be the tachs or the props.
Mbam is offline
Old 05-21-2002 | 07:41 AM
Kentz
Yes, power steering pump, you may also notice the engine runs a little hotter than the other, mine does.
Old 06-14-2004 | 10:17 PM
sightunseen's Avatar
Default Re: 496HO Alarm Problem Fixed
Is it possible that water in fuel could cause the two beeps every minute. Both of my engines are beeping. They also will not idle.
sightunseen is offline
mikebrls
8
02-03-2008 12:42 AM
bouncedcheque
3
08-16-2006 02:11 PM
29 OUTLAW
07-17-2004 10:38 AM
waden54
3
06-24-2002 10:34 PM
BillR
5
05-02-2002 12:23 PM
