557 H.P Supercharged Small Block Chevt >
Old 02-13-2011 | 09:49 PM
cigboat1's Avatar
Cool 557 H.P Supercharged Small Block Chevt
Well by now all you guys have heard about the 557 H.P. supercharged small block chevy in an outboard .. Wonder how long it will take someone to put an outdrive like Ilmor, Volvo, or Konrad on the back end of that engine and give Merc a run for their money ?????? And not cost $204,000.00 an engine or some other out of this world price!!!!!!! Sounds like a great weight to horsepower ratio !!
Hows that for a large crap ball that just got rolled ..
Jim
cigboat1 is offline
Old 02-13-2011 | 09:58 PM
Registered User
You can get a lot more horsepower from Merc for a lot less than 204k
HiPerf360 is offline
Old 02-13-2011 | 10:04 PM
cigboat1's Avatar
The $204,000.00 was just a figure I threw out because thats the cost of the new (1350 ) . I was just trying to put a little levity in the post !
Jim
cigboat1 is offline
Old 02-14-2011 | 08:29 AM
Couple of questions and observations.
Who would bother with a blower on a small block to make just 550 ponies.
(Mine makes 500&500 with about 10K of parts.)
Then why would you cobble a beautiful new indy together with an outboard setup when you could just install it like it should be installed?
Curious where you are going with all this- it is interesting in a "Rube Goldberg" kind of way.
Uncle Dave
Uncle Dave is offline
Old 02-14-2011 | 08:42 AM
LapseofReason's Avatar
The outboard thing looks cool, but the more you go over the 1hp per cubic inch base line the more work the motor will need and wont last as long. A small block will never have the grunt a big block will, they work fine in smaller lighter boats but I wouldn't look for them in big boats. Around here getting high oct. fuel is harder and harder, and a supercharged small block will more than likely need 91 or higher for that much hp or it will have a knock sensor and pull the hp down when on less oct. fuel. I would rather have a 600-700 cube big block thats N/A set up to run on 89 oct. fuel making 700ish HP with a 300-500 hour life span.
LapseofReason is offline
Old 02-14-2011 | 08:49 AM
WildThing47's Avatar
A pair of these on a 28 or a 32 skater would be nice though
WildThing47 is offline
Old 02-14-2011 | 12:58 PM
fantastixvoyage's Avatar
Pricing out a 500-550 small block after the miami show. Have to get a feel for where the market is at. Anyone price one out or have a feel for what they would pay?
Not sure if stroker is the way to go and probably shy away from LS for now but who knows. Carb and efi options for sure as well as all quality parts.
fantastixvoyage is offline
Old 02-14-2011 | 01:16 PM
Stormrider's Avatar
JC Performance Engines
I had one priced out a few years back.
475/475, and was very reasonably $ from a 383.
Stormrider is offline
Old 02-14-2011 | 02:42 PM
Bill Mithcell, Hardcore Racing, has alot of combinations to choose from for the street (marinazation is up to you). A good starting place if you do want an old style Chevy small block, or if you decide to go the LS route he can help you there too.
http://www.theengineshop.com/products/engines
Smarty is offline
Old 02-14-2011 | 03:53 PM
Marinized ready to roll exhaust and everything new from scratch 20-25K.
Be careful using an engine built for cars, cars dont have water reversion problems or issues with high idling.
A high idle in a boat with an outdrive = broken drive gears and blown clutches.
In a car you can run as much lift and duration as youd like to make X number appear on a dyno.
I have a a really nice 406 and if I had to do it all over again Id have just gone with an FI big block and been done with it.
Uncle Dave
