How do you change a Bravo Lower Unit ?
Don't forget the one under the anode torque tab. Silver round part about 2" in diameter. Seven total. Last thing don't forget the speedo tube if it is in the foot. Topside of foot in the front.
It is really easy Todd... but like mike said... son't forget the bolt under the anode. Been there done that. There are only two o-rings to mess with on the lower 1/2. The drive shaft one is the priority to get right!
Why are you changing the lower?
BT
BT
I was going to change to lower because I thought the nose cone was causing too much drag.
I now have determined I was sold a 1.36 drive instead of a 1.50. That explains my RPM loss.
Now I have too change the whole drive
