Airplane People
Old 03-17-2011 | 10:52 PM
Default Airplane People
I have these actuators on a set of rocker tabs. I was told they come from a Cessna airplane. Never seeing ones like these on a boat before I tend to believe it.
The question is, what is this nipple for? The pin at the top is pressed in and the angles allow it to pivet so I don’t think it’s for grease.
f_inscreenname is offline
Old 03-17-2011 | 10:55 PM
Default Fixx
Mark,,it looks like a greece zurt,,mabe it goes to the mounting bolt..
FIXX is offline
Old 03-17-2011 | 10:57 PM
99fever27's Avatar
Bleeder valve...?
99fever27 is offline
Old 03-17-2011 | 11:13 PM
Thats what I'm afraid of. Is it for air to pressurize the cylinder like hydraulic steering has? Grease? Bleeding?
I'm leaning away from grease because the pin doesn't pivot at the cylinder. It's pressed in now but who knows if it could have moved before the cylinder made it's way to the boat. Figured an airplane guy would know. Don't want to squirt grease in it when it's an air bleeder or something like that.
Old 03-17-2011 | 11:21 PM
Take the fitting out of the actuator with a open end wrench if its got greese behind it by god its a greese fitting. If its a bleeder there will be fluid of some sort probably red in color. I am about 95 percent sure its a greese fitting
flying J is offline
Old 03-17-2011 | 11:38 PM
tomtbone1993's Avatar
+1 just painted
tomtbone1993 is offline
Old 03-18-2011 | 12:46 AM
Cessna maybe, airplane no. Most likely tractor or large riding lawn mower part, from Cessna fluid power now owned by Eaton.
Likely bleeder nut. Just make sure piston is fully extended before you take it out.
Oh, and bleed in situ (attached).
Plumb_Gut_Phil is offline
Old 03-18-2011 | 06:08 AM
Pete B's Avatar
Charter Member#203
Veteran: Navy
Looks like a grease fitting.
Pete B is offline
Old 03-18-2011 | 07:12 AM
Looks like a zerk fitting to me. I am sure it goes to the top of the cylinder to grease the piston.
capt2130 is offline
Old 03-18-2011 | 07:19 AM
a grease zerk remove it and you'll find grease behind there
