Help - looking for water 525sc water pump part >
Old 03-22-2011 | 03:46 PM
Default Help - looking for water 525sc water pump part
Hi guys
I'm looking for the rear part of the sea water pump for my 525sc. It's particular because inlet and outlet are horinzotal...
Somebody could help me ??? In Italy nobody can find it
SIMONE
http://img15.imageshack.us/img15/4812/fotodm.jpg
http://img263.imageshack.us/img263/2791/foto1dp.jpg
simone7611 is offline
Old 03-24-2011 | 04:20 PM
I believe there was someone awhile back that had this style of rear covers on their pumps, cam stock on a 525SC engine. A quick look on the internet showed that MIAMI MARINE SPECIALISTS, 1950 N.E. 135th St., North Miami, Fl, 33181
Phone (305)945-7997 | Fax (305)945-3675 has one in stock. I recently convereted my standard pump cover to something similar to you current stlye by installing two 90 degree barbed plastic fittings. Hope that this helps.
Cliff
cliff_m_b is offline
Old 03-24-2011 | 07:09 PM
STRAIGHTPRIORITY's Avatar
looks like u could put the new kit on there and it would work.
STRAIGHTPRIORITY is offline
Old 03-25-2011 | 01:51 AM
I know on my Pantera, I had to keep using the original set up like he has. I tried installing a plastic housing kit and it would hit my engine mount. Not sure if the original style back plates are available anywhere.
It looks like it may be part #7 in this diagram, but the price is nuts($175) and the pic does not show the back side.
http://www.mercruiserparts.com/Show_...+PUMP+ASSEMBLY
Griff is offline
Old 03-25-2011 | 02:03 AM
c_deezy's Avatar
Looks like the one side is rusted away pretty bad.
CP has a billet back cap that you can put fittings on. But by the time you buy the cap and the fittings, you aren't going to be too far away price-wise from an exact replacement from Merc like what Griff posted.
http://www.cpperformance.com/p-329-b...p-end-cap.aspx
http://www.cpperformance.com/c-640-c...-fittings.aspx
c_deezy is offline
