hello
Old 05-03-2011 | 11:13 AM
Default hello
i got a five blade prop from my friend
thet is the only what i findon the prop
U S P A T 48028
48 815760 21
where can i find some info about this prop
i would put the prop on a bravo one drive
ncrncevic is offline
Old 05-03-2011 | 06:17 PM
No name stamped on the prop anywhere? I would say it is a 21pitch by those numbers. Is your boat having a hard time getting on plane?
firehawkcat is offline
Old 05-04-2011 | 08:31 AM
on the prop is no name
i got the prop so i dont now anything of the prop,only the numbers
Old 05-04-2011 | 01:09 PM
Mercury "High Five" 21 pitch. What are you putting it on... hull and power?
chewymalone is offline
Old 05-06-2011 | 12:11 PM
I will try to put it on my rib with bravo one drive,
it is 6.60meter long, and the engine have 450 horsepower
Old 05-06-2011 | 03:04 PM
Sounds about right. I'd suggest you research what thrust washer you need to use if your friend didn't include one.
Old 05-06-2011 | 03:39 PM
I have only the prop, what i need more ?
i was searching for a mercury Maximus prop but he giveme this one for a gift
Old 05-08-2011 | 11:06 AM
The Maximus is a lot of prop for a single 450hp motor in the size boat you have. What prop was on the boat before? What is your drive ratio, and what was the boat's performance with the current prop? The High5 is rather tiny in dia. so if your looking for a 21" or so, with more blade area, you should look into the Revolution4 21" or Bravo1 22" prop. The Maximus is normally used on hi-perf boats with the drives mounted high. What is your x-dim. and speed goal? Is the speed GPS or pitot speed?
Regarding the thrust washer, your local merc shop can sort you out. Mercury reccomends that you use the solid hub kit, when running more than 400hp.
A.O. Razor is offline
Old 05-11-2011 | 05:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
835467 1 Thrust Washer should work fine.
I'd try a larger diameter/blade area propeller as well.
Brett
[email protected]
bbladesprops is offline
