Scarab 29 single prop
Does a 4 blade is better than a 3 blade for the scarab 29 with a single 525sc?
Is that 4-blade hold the hull up more of water than the 3 blade?
If it is hold the hull up in water with a 4 blade i think the boat will run faster. Is that someone is already trying that 4 blade on this boat with the same hp that i have?
Yes i have the factory setup. But i think if i can lift the hull i will gain some midrange and top mph. i want to try an 4 blade like the bravo 1 or the revolution 4. Now i run with a mirage plus 25p at 5100 rpm.
Does anyone have experiance with this boat and prop setup???
How much HP do you have ? Your RPM is high what is your engine?
The mirage plus is i think 200 RPM slower than the mirage for the same pitch...
You won't believe me but it is a natural 461 that seems to run good. I didn't build it, in fact I just bought the boat in october and only got to take it out once. It was cold out and the engine ran great! I wanted to buy a blower for it but it turned out the exhaust was junk so I bought a set of cmi's. I changed the guages also so I am interested to see what a different tach will read.
Some many people on old thread in this forum talk about this boat and with a single engine they say to tuch 70 MPH this boat need a minimun of 500 HP and with a Merc 502 415 HP he can get about 62-64 MPH
My boat is also an new buy from this year so i have some test to do with prop i want to try a 4 blade prop.
