Yes i have the factory setup. But i think if i can lift the hull i will gain some midrange and top mph. i want to try an 4 blade like the bravo 1 or the revolution 4. Now i run with a mirage plus 25p at 5100 rpm.
Does anyone have experiance with this boat and prop setup???
check where your propshaft is to the keel. boats that we call deep are 6'' to 8'' = mirage or rev 4 props. b1s are good for 5 1/2'' to 3'' for heights, 5 blades 4'' to 0''. on the 5 blades px5 max 5 are bow lifting, p5 are more stern and for cats. the rev 4 is a great prop the deep or stock heights. imco shorties work well on most boats and most pick up 2 to 6mph. I picked up 8 with a carb change and 2'' shortie on my baja 24 ol with 650hp went from 5200 to 6000rpm = 76 to 83 plus. more with a prop change. good luck. Art
