trailer tires.. bias vs radial
I am looking for input on a set of trailer tires (225 75 15). I need to replace them soon and looking for opinions on which way to go and what brands to consider. I do not have far to travel to get to the water, however we do take two long trips to LOTO every summer. I am pulling 28 foot Donzi zx on a aluminum trailer. I have used both bias (carlisle) and radilas (marathon) on my previous boats, cant say I would run out and buy either again. Thank you.
I saw the other day that Carlisle now has this size in an E rating. I've had problems with Carlisle berfore, but this may be an improvement. I personally have had good luck with the Goodyears but I know there are lots of real world bad stories. Has anyone had the Carlisle E tires?
I would go with load range E if you can. But depends on how many axles you have and how much that boat weighs. I got FALKENS from Sears online that were 235/85/16 for 105 a peice. That includes shipping and installation. Basically free unless you want new valve stems and balancing, which i couldnt balance my tires anyways. Found these for you
http://www.sears.com/shc/s/p_10153_1...2&blockType=L2
Either way I wouldnt get wrapped around the brand of trailer tires. The things dont last that long anyways and they are on a trailer. To me as long as they are load range E on that big of a boat, and cheap Id put em on
Bias ply will handle being pushed sideways across solid ground better than a radial will.. If you have to do some jackknifing to get your boat in and out of storage, the belts in the radials will come apart during sideloading and then again going down the highway..
My experience : radials appearance looks good no matter age or after hitting pothole. Therefore if you are not really observant of the radials condition, you can have a failure. Bias tires show age and wear more. Also bias lose air more. I'm sold on radials for their foot print not deforming under load like a bias. The radial runs cooler because of not deforming. Cooler tire is important to prevent blowout when it's really hot or tires start aging. Most important, don't use a car tire on a trailer. Car/truck radials are just not as durable or stiff enough sidewall as an trailer tire.
