Speedo Stopped working??? >
Old 06-10-2011 | 08:07 AM
Default Speedo Stopped working???
Took my 27 Fever out last night and the speedo wasn't working. Are there any quick things I should try to fix it before digging deeper. Any ideas would be appreciated.
TC G is offline
Old 06-10-2011 | 08:46 AM
Is it a GPS model or a Pitot tube one?
techman is offline
Old 06-10-2011 | 09:55 AM
If its GPS the antenna is probably not working. I had to replace mine after 5 years.
carcommander is offline
Old 06-10-2011 | 10:08 AM
You could have just replaced the battery instead. Impossible according to Livorsi, but then again, what do they know...?
mapism is offline
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
And if it's pitot it's clogged. Small hole on leading edge of the outdrive. Take a small drill bit by hand to try and work it loose. Don't cram anything in there too far.
Baja_342 is offline
Old 06-10-2011 | 01:13 PM
If you have a Livorsi GPS unit, then here is the option from Livorsi:
http://www.livorsi.com/catalog/gps_antenna.htm
My antenna battery died on mine after 5 years and I chose to bypass the antenna puck and plug the speedo directly into my GPS/Chartplotter.
Good luck.
techman is offline
Old 06-10-2011 | 03:42 PM
Good luck.
Wow I bought a GARMAN antenna for something like $95
Wildman_grafix is offline
