Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
twin to single conversion on a CAT >
Old 07-10-2011 | 06:42 PM
Default twin to single conversion on a CAT
hi! i found a good deal on a 27 eliminator (hull only)but it has twins. i want a boat with a single.
(i know i know every body seems to like twins but i dont really want two engines sepecially in a 27 foot boat. )
my question: can this boat be converted to single engine? and if so wht would need to be done?
i am a mechanic and do all of my own work so the labor cost is not an issue.
thanks to all for the help in advance!
2tonchevy is offline
Old 07-12-2011 | 11:50 AM
glassdave's Avatar
Neno the mind boggler
Did the factory ever offer that hull as a single? i know they do now but not sure what kind of weight difference there is. As long as it has a pod i dont see why it wouldnt work but you may be in uncharted territory. You would need to put a transom in it to start
08 OPA High Points Champion
glassdave is offline
Old 07-12-2011 | 03:06 PM
i reall ydont know if it was ever offered with a single...or if it would even run worth a damn with a single. it has a pod in the back.....but from what ive read this hull is a terd (slow) any way. twin 502 only gets you mid 80s?????
thats weak.
