Stumped????
Old 07-18-2011 | 09:45 AM
Default Stumped????
I took my baja boss 302 out this weekend and had a problem. This boat has twin 7.4 mpi's in it with bravo 1 drives. When I went to take off from idle the starboard side drive seemed like it was cavating alot. When I got on plane it wanted to make a hard left if I let go of the wheel. Also the engine's rmp's where alot higher .
I had a problem with a hose on the trim pump at the begining of the year. I fixed that and have been out around 8 times since then. It seems like the same problem i had before, with the drive moving up as I took off, and the boat going left.
I checked today, the drive oil is a little milky in that pump assembly, but i checked and there is no play in the drive . If the drive is all the way down, it has no play trying to come up.Just thinking maybe I didnt get all the water out from last time, and it just mixed in???
Any help would be great????
drunkstang is offline
Old 07-18-2011 | 11:01 AM
pull the prop and check the hub
Hot Stepper is offline
Old 07-18-2011 | 01:27 PM
What should I be looking for???? What do you think the prop is slipping?????
Old 07-18-2011 | 04:15 PM
sounds like one of the rams has given up but i suppose changing out the fluid is a quick and easy test
stevesxm is offline
Old 07-18-2011 | 05:29 PM
fixed the problem. Thanks guys!!!
looked like the hub was on its way out. Looks like it spun a few times, and I cleaned the contacts on the pump. Took it for a ride today and all is good.
Now I have to clean out the oil in the lines and holding tank to get all the milky oil out from the line breaking eailer in the year... ( any easy way of doing this???)
Old 07-18-2011 | 08:31 PM
Diesel fuel is a great solvent, and since it's petroleum, it won't harm the seals. Drain the reservoir, fill with diesel, run the rams up and down a number of times. Then drain and refill. You may want to re drain the oil one more time to get all the diesel out.
Darrell.
DMOORE is offline
Old 07-18-2011 | 09:59 PM
Don't put diesel in a hydraulic system. Use the same fluid as is suposed to be in there.
dodgezilla04 is offline
Old 07-18-2011 | 11:40 PM
While I don't think the diesel will hurt anything, I would just empty out whats in there and refill a couple times with 30wt oil.
Griff is offline
