Timing Chain vs Timing Gears >
Old 07-23-2011 | 06:32 AM
Craney's Avatar
Default Timing Chain vs Timing Gears
Is there any advantage using timing gears over a timing chain??
Craney is offline
Old 07-23-2011 | 06:37 AM
articfriends's Avatar
When I was a teenager I thought gear drives were the coolest thing, could never afford one then though. As I have gotten older I have read and been told that they have a higher parasitic hp loss than a quality chain. Personally, I would buy a quality/premium timing chain set, make sure when you look at it the chain rollers are "seamless", do not have a "seam" across the roller, they can split at the seam or start disintegrating under hard use, Smitty
articfriends is offline
Old 07-23-2011 | 07:05 AM
rgrgoog's Avatar
Well on Harleys the gears will be alot smoother/more reliable and free up some HP. No chain to stretch or wear out either. Not sure about other motors though.
rgrgoog is offline
Old 07-23-2011 | 08:41 AM
The chains dont "stretch" like in the old days....unless you got 200K miles on a motor...lol. A quality chain is the way to go. The problem with gear drives..is that they send any and all vibrations thru your whole cam/valvetrain system. Basically, there is alot more wear and tear on a motor with a gear drive setup in it. It's a direct drive system, as opposed to a chain which acts sorta like a buffer in the system.
tinman565 is offline
Old 07-23-2011 | 10:25 AM
bcfountain's Avatar
Registered User
your right,gear drives are harder on the valve train because of the harmonics tranmitted.the chain acts as a shock arrester.they sound pretty cool though.
bcfountain is offline
Old 07-23-2011 | 10:43 AM
cost you h/p...chains/belts much better
ezstriper is offline
Old 07-23-2011 | 11:23 AM
Then suckers are loud too! They don't call'm a "poor man's blower" for nothin.
picklenjim is offline
Old 07-23-2011 | 11:44 AM
Too much harmonics and not good for sustained higher rpms. No marine engine builders use them and that should tell you something.
Griff is offline
Old 07-23-2011 | 12:30 PM
Then Y are they in most every NAVY ENGINE !!!!!??????
BTW..also in my racemotor..and no problem at all !!!!
relaible power a lot of it ..!!!!!!!!!!!
Just sayin'
DareDevil is offline
Old 07-23-2011 | 05:06 PM
GPM
Just curious, have any of you actually run a gear drive in a marine application to know this, what brand ? what motor ?
GPM is offline
