Single vs Twin engines
Old 07-27-2011 | 05:15 PM
Default Single vs Twin engines
I am looking at getting back into boating. I used to have a Scarab with a 350. First off I will be only doing freshwater on the highland lakes in central Texas(Travis and sometimes Canyon Lake). Aside from some obvious benefits of a twin(extra engine if one goes down, more power, easier finesse turning around the dock) what other benefits am I looking at? Also, the downsides(twice the gas, maintenance and weight). I am looking at another go fast but also a cabin cruiser, neither over 30 ft. Any input would be appreciated.
rexmitchell is offline
Old 07-27-2011 | 05:23 PM
Sydwayz's Avatar
Forum Regulator
Hate to have to do this, but use the search function.
This topic has been discussed at nauseam.
Sydwayz is offline
Old 07-27-2011 | 05:24 PM
As awesome as the search functions are on forums, I searched around but didn't come up with alot of info
Old 07-27-2011 | 05:33 PM
Sydwayz's Avatar
Forum Regulator
http://www.offshoreonly.com/forums/p...gle-twins.html
http://www.offshoreonly.com/forums/s...ns-single.html
http://www.offshoreonly.com/forums/g...uel-usage.html
http://www.offshoreonly.com/forums/g...intenance.html
http://www.offshoreonly.com/forums/g...big-block.html
http://www.offshoreonly.com/forums/g...mall-twin.html
http://www.offshoreonly.com/forums/p...ns-single.html
Sydwayz is offline
Old 07-27-2011 | 05:34 PM
Thank you
Old 07-27-2011 | 08:17 PM
97FASTech's Avatar
Veteran: Army
Let me know when your at Canyon Lake, I boat there.
97FASTech is offline
Old 07-28-2011 | 09:52 AM
I think the maintenance issue is a catch 22. Obviously its less to maintain two than one, but on a heavy 28ft boat the cost can be less overtime to maintain two motors. A heavy single engine 28ft boat will go thru motors and drives much faster than a twin. In the long run I think you may find it cost more to maintain a single high performance 500hp+ motor and drives than twin stock 415hp 502's or 365-385hp 454's on a heavy 28ft boat. In short, assuming a single engine 28ft boat has 500hp+ it will have shorter rebuild time and cost just as much to refurbish than a twin engine stock setup. Gas on a single vs twin is about 25-33% less, not the 50% you might expect.
Balance is also a catch 22. The torque steer of a single engine sucks much worse than a heavy rear ended twin setup IMO.
There really is no free lunch with either setup on a big heavy 28ft + boat.
TexomaPowerboater is offline
Old 07-28-2011 | 10:38 AM
good post.
Also, if you break down with one engine you are being towed. That can get old. On smaller lakes not a big deal but in big water lakes/ocean different story.
I run a 28 single with 675HP and an IMCO drive.
ar15meister is offline
Old 07-28-2011 | 10:44 AM
Indy's Avatar
Member #154
Depends also on the age/condition of your motors. Older motors and drives will break your bank. After having both I'd never to back to a single, I will however make sure that my next boat is newer with low hour/age motors.
Indy is offline
Old 07-28-2011 | 02:34 PM
p:Single not get home twin get home
PARADISE ISLAND is offline
