Hydro 5 To Bravo I Rpm Diff! >
Old 06-06-2002 | 05:18 PM
Goodfella's Avatar
GOT MERC?
Exclamation Hydro 5 To Bravo I Rpm Diff!
Just got done doing some back to back testing from a Bravo I 4 Blade to a Hydromotive 5 Blade. The rpm difference from pitch to same pitch is approx 500. The 5 blade will turn less rpm then the Bravo I. The slip factor in the boat decreased dramaticly when the 5 blade was run after the Bravo I. So if you are turning a 32 P Bravo I at your recommended RPM you need to run a 29 P Hydro 5 blade approx. Every setup will vary slightly in RPM and PITCH.
Goodfella is offline
Old 06-06-2002 | 05:38 PM
Smitty's Avatar
Please give us the details such as what kind of boat, how much H.P., any speed differences and what kind of X-dimension.
Thanks,
Dave
Smitty is offline
Mike, Very interesting, What happened to the MPH? can you post the numbers? RPM, Gear Ratio, etc. Slip.
Philip
Philip is offline
Old 06-06-2002 | 05:48 PM
outer42's Avatar
goodfella, I thought of trying them. i run a 32 bravo on xr drives w/ 650 hp I tryed to turn a 34 and the boat handle like sh$$ and lost m.p.h and only could get 5100 out of it. the 32 puts me off the limiters. what do you recomend? i havent spoken to dennis yet. thanks for your advise.
p.s 37 outerlimits w/ stagered motors
outer42 is offline
Old 06-06-2002 | 10:27 PM
Goodfella's Avatar
GOT MERC?
Cool
Here is all the info I have:
37 Active Thunder
Twin 675 KE SBS
outer37, You should think about trying a set of 30 or 29 Hydro 5 if you are running 32 Bravo I at your recommended RPM.
Philip&Bigwavz,as soon as I get the authority to release more info I will.
Old 06-06-2002 | 11:35 PM
Sounds like ThunderDan! What speeds?
Pure Energy is offline
Old 06-07-2002 | 12:29 PM
Cattitude's Avatar
Default Single cat results/
Mike,
If and when you ever get some results on a high x single cat please post it. I may have the opportunity to "borrow" a 28" hydro 5 in a month or so. running a labbed 30 now with 10.5% slip (best conditions not duplicated every day)
Thanks,
Cat
Cattitude is offline
Old 06-07-2002 | 12:39 PM
thunderdan's Avatar
We tried the 31p 5 blades, could only turn them 4500 rpm's at 88 mph. It is looking like we need some 28p 5 blades. These are KE 675's, bravo xr's with 1:36 gears, slip was about 9.5. The boat did really like the 5 blade props though.
thunderdan is offline
Old 06-07-2002 | 01:10 PM
jbrauer's Avatar
Default Thanks!
Great info! Keep it coming on the Hydro 5's.
I think they may be the ticket for the high X on my cat and they sure would make a nice Xmas present when the time comes!
jbrauer is offline
Old 06-08-2002 | 11:41 AM
Goodfella's Avatar
GOT MERC?
Cool
Thunderdan,
Thanks for the info Hydromotive is supposed to release the 26-29 pitch versions sometime in July. I will let you know Thanks for stopping by and checking out the faciltiy.
Boomer35
Prop Talk
4
09-12-2008 04:15 PM
littledcsrodshop
Prop Talk
5
06-13-2008 12:54 AM
mopower
Prop Talk
5
07-18-2006 07:58 AM
Harper220
Prop Talk
6
03-07-2006 10:57 AM
stevejohns
4
07-09-2002 11:01 AM
